Old 11-10-2004, 04:06 PM
tfarhood tfarhood is offline
Cobra Make, Engine: Backdraft #101, 342 stroker
The Dremel tool with a sanding drum works great. I did my own install and made the holes the right size in about 15 minutes each. If you hold a shop vac close to the hole, you won't have any clean-up after either. The Dremel is priceless for this task.
tfarhood
