  #27 (permalink)
Old 11-11-2004, 02:19 PM
NASSTY NASSTY is offline
Cobra Make, Engine: RCM, 4 wheels, two doors
Oopps!
Out of my league here!
Finished trimming back my drivers side door. I had gaps up to 13mm now the leading edge is 5mm (with the remander 1-3mm). This can't be any smaller or else the door won't open!. Now I just need to make the 5mm gap all round and then onto the next door.
Les and vettestr thanks for the info re filler. I have two areas on the drivers side door I need to build up (max 1-2mm) so the info will come in handy! First is some concavity on the leading edge of the door and second is on the body in front of where the top of the door turns inwards.
I've also been told to just use bog to sandwich the inner and outer skins together. This method has apparently worked well and I know of others who have also used re enforced filler (but it's a pain to sand).
Any thoughts about this?
