Old 11-12-2004, 07:01 AM
Timmy Timmy is offline
This procedure explains how to do it. This procedure will work on all FE series Ford big block engines however, you may or may not have to raise the motor to remove the oil pan. Depends on application.
Hope this helps…….
http://www.squarebirds.org/rear_main_seal.htm
