Old 11-15-2004, 09:15 AM
Shell Valley Shell Valley is offline
Cobra Make, Engine: Shell Valley, 514 SVO ... now a 4.6L with an AOD!
It sounds like a bad dimmer relay. You can test the relay by taking the white wire (at the turnsignal switch) and touching it to a ground. This should cycle the relay between hi and lo beam. If it is the relay, give me a call and we'll get you a new one.
Thanks,
Dana
