Old 11-15-2004, 07:19 PM
A Cobra guy A Cobra guy is offline
Cobra Make, Engine: E-M , 5.0 efi
Tommy,
I'm not bragging but I put my E-M boddy on by myself! Well, my 70 year old father was there to help line it up. The body is so strong that you can put nylon straps from the 4 mounting points on the floor of the cockpit to a central point. HAve the rears a bit longer as the center of gravity is up near the dashboard. All this was hooked to a come-along that was attached to a sturdy beam in my garage. I jacked the body up, rolled the chassie under it and lowered it back down. Use a floor jack to raise it up the first couple of inches. This will be a good way to tell if anything is still hooked up. Then you can put eye bolts down through those 4 mounting holes. Doing it this way I would leave the doors on and keep them latched during the lift.
I think I still have pictures if you want to see them.
Harevy R.
