Old 11-17-2004, 08:12 AM
JL1924 JL1924 is offline
Cobra Make, Engine: Shell Valley Cobra. Engine is a Ford Racing 302 Crate motor, with Tremec 3550 5 speed trans.
Dana,
There is no white wire at my turnsignal switch.
The colors coming off of my turn signal are as follows:
Black with green stripe----------------->Right turn signal
Grey w/black stripe---------------------->Left turn signal
Brown w/white stripe w/jumper------>To dimmer relay
Brown single wire----------------------->Ground
Black w/blue jumper-------------------->HOT
I tried grounding the brown w/white stripe wire with the headlight switch on but did not hear any cycling of a relay and still had no headlights. Would this be the indication if the dimmer relay were bad?
Jim
