Old 11-18-2004, 01:28 AM
FFR428's Avatar
FFR428 FFR428 is offline
Cobra Make, Engine: HM-2027 / 427 SO
Is the oil pump a std, high volume or hIgh pressure? It's also possible there may be some junk in the pump or tolerances are way out. What kind of oil pan and pickup are you using? As stated you might be starving the pan if you swapped out a std pump for a HV type. G.
