Old 11-21-2004, 05:53 PM
CCX33911 CCX33911 is offline
Cobra Make, Engine: Contemporary, 427 EFI; CAV GT40, 427W
Get one or two quart bucket. Remove pan. Run drill with bucket full of oil under pickup and a big drain pan under engine. While pressure is at max, look at leakage rates. There should only be heavy drips to small streams coming out of bearings. If you see a large leak pooring out oil then find where it is comming from, etc. Those pumps flow a lot of oil so it would have to be a big leak. You can buy an adjustable pressure pump from Melling (racing style pump),
Thanks
Gary
CAV GT40 Dealer
www.2gmotorsports.com
