Old 11-25-2004, 09:19 AM
cobra de capell cobra de capell is offline
Banned
Cobra Make, Engine: ERA 428 FE 4-speed CR "TL" heavy spline
Originally posted by strictlypersonl
We always installed the emblems with push-nuts on the stud but it sounds like yours are stuck on with adhesive.
If you can see the push-nut on the stud from the back, they can be pried off or pulled off with needle-nose pliers.
To remove one that's held on with silicone, carefully apply masking tape all around the emblem. Then, use a very thin putty knife or thin blade to first cut through the adhesive, then pry it off.
Actually, mine are installed with push-nuts on the stud with some sort of rubbery stuff on the inside of the body around the push-nuts and studs. I can easily remove the rubbery stuff and use the pliers as suggested. I suppose the rubbery stuff will remain a mystery to me, but as long as the new emblems stay put - I'm a happy camper.
Thanks for all the input on this thread.
