Old 11-25-2004, 06:57 PM
cobraleonard cobraleonard is offline
Cobra Make, Engine: 1995 CMC 390 4 speed, blue, and 2002 CMC 390 C6 red.
It appears that you are "thinking thru" the process and that leveling the the frame is the correct way to approach this step. I didn't say before but assumed you have your drivetrain in? This would "weight" the frame and further help you to center the frame/body . I thought when I did mount my bodies, it was very helpful just to set back as far as I could and look to see the tire clearances. This will be one of your best guides and think of it this way , it will be the the way the car will ALWAYS be seen. One more thing, if you are using coilovers, make sure they are adjusted the same, allowing for tuning adjustment.
Joseph
