Old 11-26-2004, 08:46 AM
wilf leek's Avatar
wilf leek wilf leek is offline
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
Just a thought:
In addition to the other excellent advice meted out, check to see if your tank is properly vented.
The symptoms you describe could easily be explained by a vacuum build up in the tank as the fuel level drops.
If it happens again - jump out and pop the filler cap. If you hear air rushing in as you do so, there's a big clue.
Wilf
