Old 11-28-2004, 03:00 PM
Mike Del Mike Del is offline
Cobra Make, Engine: Unique Motorcars 289 USRRC, 357 Windsor
If your BDR E-brake is similar to the Jag setup you have to install the return springs for the calipers to self adjust. If you do not have return springs you will adjust the E-brake and it will work a few times, then become too weak to hold the car without another under car adjustment. Once the original return springs are installed it will adjust itself each time you use it.
Mike Del
It's all in the detail.
