Old 12-02-2004, 06:33 AM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Default Got it out.....
Actually Mike, my own personal Cannonball Run from Atlanta to Tacoma might be kind of fun.....for the first 6 hours or so ;-)
I talked to Doug at ERA and he said just knock it out with a chisel. I guess I was being too gentle and precise before. Got the thing back together and figured I'd drain the tranny while I had easy access to the fill plug from the interior.
Debating if I should give it a test drive with the tunnel off in case I have to go back and change something. However, am afraid I'll end up with grease and fluid slung all over the interior.
Any tips on what I should be looking / listening for in order to make sure all is right?
I did mark the nut, shaft, and flange and got the thing back to the proper position. Didn't test the torque as I only have a 1/4" drive inch pound torque wrench, but couldn't find a large socket for that drive to fit the nut. However, could move the flange about a half inch turn with my hand with a relatively stiff resistance. My bionic arm and SWAG powered brain indicated it was " jest 'bout rite."
Thanks!
Scott
