Old 12-02-2004, 06:57 PM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Thanks for the info, Michael C Henry...I did a some further research, and came up with the following info: 1995-2000 Chrysler (Cirrus) 2.5L V6 engine Stant # 14128, Gates #33878, Beck/Arnley #1430713. I'm not disagreeing with decooney, this just gives another option. The Stant thermostats are available at the local Advance Auto, the high flow stats aren't.
Dan
UPDATE: Depending on how the intake was machined, these thermostats may NOT fit. The back of the thermostat is both longer, which hits inside the intake on a Tunnel Wedge and probably some others, and the rear support structure of the stat it too large for a sidewinder and probably some others, most likely post-'67 units.
Based on this info, I suggest not using these particular stats.
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
