Old 12-06-2004, 11:43 AM
Larry N Johnson's Avatar
Larry N Johnson Larry N Johnson is offline
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
Dear Big_texan,
Thank you for the question on the Serpent Express (SE).
The dimensions of the Coupe from the FFR web site are:
Wheelbase 95 in.
Track (Front/Rear) 59 in./ 58.5 in.
Overall Length 174 in.
Overall Width 73.5 in.
Overall Height 48 in.
Ground Clearance 4.5 in.
Dry Weight 2110 lbs.
Weight Distribution F/R 44.9/55.1 (%)
Fuel Capacity 15.0 gal
Oil Capacity 6.0 qt.
The Sypder GT is the same length as the coupe as far as we know.
The standard SE-14 has a 168" deck, 6" too short for the Type 65 Coupe.
We would offer an SE-16BT that has 192" deck length.
It would have straight axles with a "beaver tail" and rear stowed ramps. Slightly taller and heavier by 125 lbs or so.
Can get a Mustang or a Camero in the SE-16BT, so you have more flexibility.
A 55-57 Chev is 16' 7" long so we would have to go to a SE-18BT for that car.
Hope this helps.
Do you have either the Coupe or the Spyder?
