Old 12-06-2004, 02:32 PM
Jasonj23 Jasonj23 is offline
Cobra Make, Engine: 427 side oiler
Default 427 just Magfluxed and Hot Tanked
Just had the 427 block and crank Magnafluxed and Hottanked. Everything checks out just fine. New pics can be available to anyone interested. Also have the contact # for the machinest who did the work. He is happy to answer any questions about the block and crank. Can also provide reciepts for the inspection work that was done. Thanks for looking
In answer to excalibur's question. When I listed that the crank had hollow oil filled crank throw I was referring to the plugs found on each of the 427 cranks. They are hollow and fill with oil to help balance things. But 427's have 2 types I believe. the first are screw in plugs. The second which is what I have are snap ring retained plugs. Hope that helps to clarify. Thats the best way I can think of wording it.
