Old 12-10-2004, 03:39 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Ant, to me, the gold standards of close ratio mass produced trannys are the muncie M21/22 and the close ratio toploader, of which the muncie has closer spaced gears, I think 2.20/1.64/1.27/1.0 compared to the toploaders 2.32/1.69/1.29/1.0 . I did a search on the LeMans racing vipers/vettes, and couldn't find any specs on the tranny gears, but I did find that GM offers a road race T56 for the vette, only an over the counter $8000 option, for scca racing. The gear spread was 2.29/1.61/1.22/1.0/0.85/0.75 , which is a lot closer than what the T56 is offered in the street camaro's, vipers, vettes. To me, this is a true close ratio 6 speed, and is probably close to optimal gear spacing for a V8 powered mid sized race car.
If you got a custom 5 speed tranny, with the first 5 gears similar to this, basically a muncie/toploader with a 15% - 17% overdrive, I think this would be the best overall gear spacing.
As the jerico and G-force trannys have 5th gear as 1:1, you would have to adjust the muncie gear ratio's, dividing each number by 0.85, to come up with a 5 speed as can be offered/designed. So, 1st would be 2.59, second 1.93, third 1.49, fourth 1.18, and fifth 1.0 , and this should be fine with a 3.07 rear. If you want a 17% overdrive, then divide each gear by 0.83, so the rato's would be 2.65/1.98/1.53/1.20/1 , etc.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
