Thread: FFR or ERA??!!
Old 12-14-2004, 03:02 PM
mpotito mpotito is offline
Cobra Make, Engine: ERA # 695 w/Shelby alloy block 427#CSX506 w/Richmond 5 speed
Yo Adrian: I bet you get that all the time. I'm not exactly sure what you are asking me but that's probably because I'm ignorant.
Here's a list of some stuff related to the motor:
Scatz 4 1/8 steel crank
Scatz H-beam rods
Wiseco pistons 10.5:1 compression ratio
Aviaid pan and windage tray
Edelbrock aluminum ported heads
Edelbrock water pump
MSD with Moroso wires
Comp Cams HRY cam & Roller set
11" dual friction clutch set
Lakewood high torque started
Lakewood bellhousing
26 spline set up
750 Holley
AT Frams Intake dual plane
Carter Fuel Pump
Billet pulleys & Alternator
Balanced,Blueprinted (with complete spec sheet) and Dyno run
cost $20,500
Fast is fun!
