Thread: Coyled
Old 12-17-2004, 07:19 AM
coyled coyled is offline
Brian, sorry, I just saw your post. I am running a 1 1/4 front speedway engineering sway bar. The sway bar along with the 600 pound springs makes the front very stiff. Wheel rate is 385 pounds. You can contact speedway engineering but the bar might be too stiff for your liking. I have a 1 inch front bar in my garage that I was useing that mounts like a typical sway bar. It is an original style bar that would bolt on a hi-tech, original cobra or a kirkam. I do not know if it would bolt on your Lonestar. If you want , you can try it and see if it fits. If it bolts up, you can give me $50. If not, give the bar back. If you add the bar, initial turn in will be better but mid corner and exit, it might push. If it pushes too much, you can add some rear rate to help. Better to have a push than oversteer. I have plenty of extra springs for the rear also. Scott
