Old 12-17-2004, 01:54 PM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
I wouldn't even drive the car unless you can get it timed properly. How could they know where they set the timing without a pointer. All they could do is guess. Timing will cause a hesitation and slight spurts as you describe. After the timing is set then you can get into carb and such. Accelerator pump not adjusted properly will cause a slight hesitation. Without proper timing you could easily melt down the engine.
Don
