I came from DesMoines Iowa,Moved away in 75.The wires I supplied are larger than the wire that came on the componets. It turns out that the yellow wire I thought was wrong was a resister bypass wire from the starter relay.So next thing to try is to bypass the resister.I have questions about the little power filter to the distributor.it is mounted off the front of the intake and abovethe coilbetween the coil and distributor.The Hy Fire Vi box wiring diagram shows a wire in the pair of wires that I figure are the memory power and ground. Do you think the actual HyFire VI cd box its self needs to be grounded?
Mike H
