Old 12-19-2004, 06:34 PM
scratch scratch is offline
Scales,
Mounting the body is important, and you can do it, but you should go slow;
IN addition the the "left/right comments...here are a couple of important notes I didn't see in the thread:
-The rollbar positioning is CRITICAL before and after mounting.
-The butt of the body can be "up" or "down" can be effected by how you mount the rear on the chassis. By the way, moving the body around without support between the front and rear of the "cockpit" can break the bottom door jams. I used a board with stops.
-In addition to the four penetrations on bumpers, I would bond 6+ hard points around the wheel areas to hold the body to the frame. At the frame, use or make hot rod type brackets which have rubber on both sides.
-I mounted everything with rubber cushioners, to keep the FRP from taking too much stress.
scratch
