Thread: Coyled
Old 12-20-2004, 07:13 AM
coyled coyled is offline
Brian, mine has the long bolt with the rubber mounts, it is not the speedway style bar. Mine used to not turn in well at all. The push has to do with the narrower front track. You need to go up in front rate with bar or springs. It will turn in much better but might push mid corner or exit. The stiffer front will give you more rear traction at the exit. You might have to add more rear spring to balance it out and your adjustable shocks can control transients. Let me know if you are interested in the bar. Scott
