Old 12-23-2004, 04:18 AM
Tom Hi Couple of things, Is your drivetrain strong enought for 600 to 700 hp and about the same in tork? Have you driven your car without the blower yet, I would start there and when you are SURE you can drive your car well then add the blower. Fuel system do you have a supply large enough ? Min 1/2" lines, Large pump with a 70 psi limit, bigger injectors, for your motor 50lbs. min. You might want to look at 72lbs and have less open time on the injectors. Re program the ECU with a retard system, MSD. Pulleys and how much boost do you want to make. The pistons should be coated both sides and tops to prevent dentenation. Hope the block is season for after market and strong. Limit the boost to NO MORE than 8 psi. You will need good gas. Look at intercooler or water injection to help. I have been there and done someof the things you are about to try. Rick Lake
