Old 12-23-2004, 05:01 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Dang MIke, you made ma put on my glasses. Okay, the resistor is needed for any period where the car may stop running but the ignition will be on. And, over a perioid of time the coil will heat up if you run the car with out the coil.
Given that, the 12V is for the Infrared module in the distributor. The green wire will drop to something like .2 V when the shutter is open making the coil see a differential and fire. The Positive terminal of the coil should see some thing like 8 to 12V, depending on the resistor.
SO, the box, which I determined to be twitchy takes the place of the resistor and adds "enhanced" spark. Yeah, well I had a number of conversations with them and they just about told me it would die if I took the box off. Personally, I am not going to use it.
Want to hear a nice trick with your setup ( seeing how it is the same as mine ) I used the .85 Ohm resistor and wired it directly to the coil as designed. Then I fused it to a seperate line at 15 Amps. What I found was people sit and play with the insides of the car with out asking. The fuse will blow after about a minute, IF the car is not running.
I have had to replace the fuse three times in cases where the person(s) confessed to sitting in the seat.
The car will not run without the fuse in place.
Another thing, depending on who you talk to at Mr Gasket, you may get the voice of doom about the unilite module and "overvoltage". I have not had this happen yet, but acording to them, the modul may cut-out or die if exposed to voltages above something like 15.2V.
You can fix this if you wish, two capacitors and a TO-3 cased 7812 voltage regulator. It is what is in those little "protection" moduls they sell for $35.00 ( or more ). Don't have one myself, but I considered it for some time.
I was wondering what you have your initial set at? I have something like 36 total and only get 18 to 20 out of the distributor, but the CAM eats up the advance.
Well, back at you.
