Cleaning house- Lots of parts
Cleaning house again. I have lots of parts around.
TFS R heads- new w/Ferara valve- Will set up for your cam. $1400
SVO Iron 351 simese block and 4340 351 steel crank- needs 1 sleeve. $1000
65mm and 70 mm Edelbrock T-bodies- new $150 each-SOLD
65, 70, and 75 Edelbrock EGR spacers- new $50 each
Offy dual 4 intake for FE- uses spread bore carbs. $150-SOLD
2 used AOD tranny's- used $75
347 stoker kit- long I beam rads, 4340 crank, forged pistons, 10-1 compression. New $1100
Performance distributor's electronic distributor for 302- new $150-SOLD
Speed Pro hyperutectic pistons for 302, .030 over. New $100
Tilton Floor mount pedal assy- new $100- sold
Cross drilled 4 lug rotors for Fox spindles- slightly used. $40
Detroit locker for 8.8 diff- used- $200
Lots of Fox body parts- hoods, doors, bumpers, Wheels, etc...
Call 480-446-8442
