Thread: Gas Tank vent
Old 12-29-2004, 02:47 PM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
There are two vents on top of the tank. They are Brass inserts.
One is for the pressure regulator return line and the other is the tank vent tube connection. I recommend using the one close to the sending unit mount as the filler neck vent.
Did you install an access port in your trunk? If you did, all you need to do is run a piece of rubber gas hose from the brass fitting to the small tube on the side of the fill tube. If you did not install the access port, drop the tank and connect the 3/8" hose that way.
If you do not have a vent tube on the filler neck, make one,
Hope this helps.
