Thread: Tremec roll pin
Old 12-29-2004, 07:45 PM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Question Tremec roll pin
Lost first and second gear today on my TR-3550. Found that the roll pin holding the first-second shift fork to the shift rail had come out. Dumb question is - where do I get the correct roll-pin? Are these just off the shelf hardware items from Home Depot or are they special and specific for transmission use? Also, since the pin is gone, I'm assuming the magnet in the bottom of the pan will pick it up, or do I need to drain the pan and go fishing? Also, if it's an off the shelf item, how do I best determine the diameter and length of the pin?
Thanks!
Scott
