Thread: Oil Pressure
  #27 (permalink)
Old 12-30-2004, 08:45 AM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
Interesting...
I had a similar (though) opposite experience. I used Fram filters (2 one quart filters) during break in for my 427 with a HV bluprinted oil pump and a HP bypass spring in the block.
I got 85-90 psi at speed (over 2500 rpm) and a low of 50 or so at idle. After 500 miles I went to Bosch oil filters. I got 70 psi and 40 or so at idle. Same brand oil, 25/50 Valvoline, same temp. It wasn't gradual... Bam it just changed.
I switched to bosch after reading a thread about Fram and some of the specs from a website that did an exhaustive analysis of the filters contents and build materials. Napa Gold (WIX) and Ford FL-1's were among the highest rated. Mobile 1 filters were rated pretty high too.
It may be Fram just has really bad quality control. I can't imagine a 30% increase or in my case decrease from using one brand to another. I'm almost ready for an oil change again. I have a pair of Moble 1 filters and was going to wait for 2500 miles on my new engine to switch to synthetic 20/50. I'll let you know what happens then.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
