Old 12-31-2004, 12:48 PM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
Same thing happened with my wife's Cherokee. Turned out to be the "crankshaft sensor" in the distributor. Replace it before it completely fails and leaves her stranded. Mine died as I was driving it up out driveway, fortunately.
Another possibility is the the wire going to the ignition module in the distributor. My wife's Volvo had a wire that had become frayed inside the distributor. I had tuned the car and broke off the last of the frayed wire without realizing it. Took a while to figure THAT one out. A soldering iron and burnt finger tips fixed that one.
One last thing I'd check is the coil: My wife's Volvo (glad I sold that thing) was dying while she was driving it. After it cooled, it would start back up and run fine. The coil would get warm and then the expanding metal would create an open circuit. Once it cooled, it would close the circuit and start and run again. The dealer putzed with it for a couple of days and said their was nothing wrong with the car, and then a day later my wife was stranded once again. I got out my Tektronix voltmeter (I used to work at Tektronix) and checked the voltages at the coil poles, then drove the car around until it failed. Once it failed, I checked the voltage again, and one pole was now at ground instead of 12V. Replaced the coil and off it went.
Good luck, and Happy New Year,
Dangerous Doug
Dangerous Doug
"You're kidding, right?"
