Old 01-02-2005, 01:27 PM
cobrajeff's Avatar
cobrajeff cobrajeff is offline
Default Webers on a 351 in an ERA FIA
I think you may run into clearance problems with the Webers on a 351W in an ERA FIA. I have an ERA FIA with a 351C in it - and the Charley AND the Webers were BOTH a tight fit. Here is a shot of where they sat when I started:
After seeing how close they were to the underside of the hood scoop, I had 1/4" milled off the top of the intake manifold (carb mounting surfaces). There are other pictures in my gallery showing the Weber manifolds, before and after cutting. The engine shot with the unpainted block (and one cast-iron and one alloy head) is before I cut the intake.
The 351C deck height is 9.2"; your Windsor is likely 9.5" - if you can imagine the picture above with a quarter inch (plus) of deck height, it looks like you'd be touching the bottom of the hood scoop.
Only way to tell for sure, though, is to try it - but, I think it looks like it might be an issue.
regards,
Jeff
CobraJeff
ERA P 202
