Old 01-02-2005, 01:34 PM
Ken Williams's Avatar
Ken Williams Ken Williams is offline
Cobra Make, Engine: RUCC 331ci, Tremek, 9"
Question 302 flat plane crankshaft
In 2006 i plan on building a 302 with a forged 180 degree flat plane crankshaft instead of the normal 90 degree cross plane crank.
I plan on using an iron eagle 4 bolt block.premium lite weight custom rods and lite weight forged pistons.
I need to know about flywheel balancing and what to use for a harmonic balancer on the front. since the crank doesn't have counter weights inside.
Max RPM on this engine will be 7,500 or less.
This engine will be used in a car less than 2500 lbs.
Are there any well educated members that can help me with my questions?
I don't think i would get a response from FORD R&D if i contacted them.
Please help me.........Thanks guys
