Thread: rear coilovers
Old 01-02-2005, 06:06 PM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
If it bottoms, your spring rate is not adjusted.
The coil needs to be loaded so the springs can do their job.
I have the same setup.
What is your bottom collar set at?
What color are your springs ( strip on side of coil )
If you have 220 or 250, you may want to give yourself at least 1/2" of thread under the collar. Set the valving to four and give her a try.
Best of all, you can call Aldan Eagle and ask for help.
