Old 01-03-2005, 06:18 AM
351-EM's Avatar
351-EM 351-EM is offline
Cobra Make, Engine: Everrett-Morrison Cobra, 427W T-5 Z tranny
Hi,
I am currently doing the same thing on my Everett Morrison. The one problem that I ran into was that the hood scoop I bought from Finishline was not wide enough to give me the overlap necessary to rivet to my hood. I still have that hood scoop if you would like to have it. I also have the jpegs of the measurements that you would need to drill the hood scoop and front hood rivets. The hood scoop I got from finishline has been drilled according to the diagram. I ended up going with an aluminum one from Cobra Restorers that was used on the cars with weber carbs. It ended up being about 2" wider and worked great. Let me know if you want it and I will send it to you, and I am attaching the diagram for the dimensions.
Thanks
Chris
