Old 01-05-2005, 08:09 PM
bmcmillan bmcmillan is offline
Cobra Make, Engine: B&B non-donor, 496 Genesis SO (608 HPwith 9.4:1 CR), Tremec TKO, Currier 8.8
Scouder,
You are absolutely right. The new FE blocks are a dream come true for Ford guys. A serious hp motor that weighs less than 600 lbs. wet and is not the size of the 385 truck motors? I doesn't get any better than that. To have that much power under your control is truely awe inspiring.
Just because you have that much power doesn't mean you need to use it all the time. My pedal is infinitely adjustable - from no throttle to full throttle.
Keep the faith.
Brian
