Old 01-07-2005, 06:16 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Blas:
I just cut and rewelded the my exhaust tips so they are pointing down at about 30 degrees and then use the car as a snow blower. Two passes and I'm through.
True story:
Have a birch tree next to the driveway and it drops a ton of little leaves in the fall. Driveway was completely covered in them one morning when I backed the Cobra out. When I got to the street and looked back up the driveway to check that the garage door had closed saw two cleared paths the width of the car apart leading back up the drive.
DonC
