Old 01-09-2005, 09:00 PM
The Dreamer The Dreamer is offline
Cobra Make, Engine: KMP329 w/KC489 Shelby
Well, I haven't seen them posted anywhere so here a picture.
If I remember from my discussion with Tom, these ONLY work with the TKO600 and use the torque arm mounting points (along the bottom of the tail housing). Looks straightforward. You need to also have the short input shaft installed. Steel moons weld on to the back of the frame cross member that has the toploader trans mount on the front of it.
BTW, thanks Don for the tip. That is what I used to reduce these photos.
