Kris
We do everything from the Centerline of the chassis.... infact we even show folks how to make sure the chassis is square....
Once we know the chassis is square then you can set up your strings from the chassis tubes.....
The way you are talking about is only after you have set the car up the way I have .......then you can make some tubes that attach to the car that go around the car to do some chassis adjustments at the track....
My next efforts will be using Laser Levels instead of string...
Bruce has a problem with Bump Steer and he would do himself a favor and go read my latest issue on how to do Bump Steer and get the car working the way it's suppose to...
Morris
Morris
