Thread: Nitrous Theory
Old 01-12-2005, 09:27 AM
bremillard bremillard is offline
Cobra Make, Engine: shell valley, all aluminum 540 ci chevy
Nitrous is real touchy and the parts it hurts are expensive to fix. The pump you are using now is barely adequate for your motor alone(in my opinion it is inadequate). If you use a single pump you will need one that is rated a mininum of 250 gph. You must follow installation instructions to the letter. You will need a #10 feed line and with a pump of this size you will probably need a return line(BG has a high volume pump out now that they claim does not need a return line). If you go cheesy with nitrous it WILL BITE YOU. -Bob
