Old 01-14-2005, 07:32 AM
RedBarchetta RedBarchetta is offline
Banned
Originally posted by Roscoe
The Edelbrock also has threaded ports so you can block the heater port and use AN fittings for the bypass.
Right click....save as. Good to know.
I recently fixed a water neck leak and had to fabricate the correct bypass from another pre-formed hose. Basically went to my local independent autoparts supplier and said "This is basically what I need." We went through his Goodyear catalog and found one example of 5/8" that had all sorts of preformed bends in it. Cut-off both ends and the middle part works perfectly without any kinks that may inhibit water flow. [b]Had I had a pump with provisions for threaded fittings, it would have been easier to route.
-Dean
