Thread: Ignore (EOM)
Old 01-15-2005, 12:48 PM
Ron61's Avatar
Ron61 Ron61 is offline
Talking
Earl,
Is that a real or Replica calendar?
Mike,
What size are the pictures that you take with your camera? I mean in KBs as they will normally run in a certain range depending on what resolution you set it at. I have never taken but one picture with mine at the highest resolution and I did that just to say I had tried it. I normally take mine at about the mid range and depending on background and etc. they run from around 700KB to 860KB. And you have a much better camera than I do, so yours will most likely have a higher default setting. But try lowering the resolution and I bet you won't even see the difference so long as you don't go to far down.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
