Old 01-15-2005, 04:52 PM
Michael Quinn Michael Quinn is offline
Cobra Make, Engine: Midstates. Ford stroked 460 (to 514) blue/white
kitcarbp, you should align an OEM belhousing the exact same way with alignment pins. They are easy to use. A simple runout gauge will give you what you are looking for. My Lakewood was only a little off. I even checked the surface accuracy and it was dead on. If you are using the McLeod double clutch setup use only the 3/4 master. Anything more will create too much travel (and WAY harder clutch pedal). Good luck!
M.
