Old 01-17-2005, 09:00 PM
bmcmillan bmcmillan is offline
Cobra Make, Engine: B&B non-donor, 496 Genesis SO (608 HPwith 9.4:1 CR), Tremec TKO, Currier 8.8
Craig,
You can make your own up with a combination of rod ends and/or heim joints attached to swedged internally-threaded steel tubes. The heim joint/rod end decision is based on how much "give" you are willing to tolerate for a smooooother ride. About $15.00 for the tube and about $15.00 per end.
Fully adjustable so you can get that perfect pinion angle or wheel base that you've always wanted.
See www.speedwaymotors.com.
Brian
