Old 01-18-2005, 09:16 AM
MidOHasp MidOHasp is offline
Cobra Make, Engine: SPF1670 Stroked Little Windsor - Runs OK.
Send a message via AIM to MidOHasp
Originally posted by trs900
Thanks racerx.. I was worried that I would loose low end torque using 205's.. a little would'nt hurt as I have plenty now.. 205's over 185's wonder how much more hp they would give.. hopefully usable..
TRS...don't forget about your cam profile.
If your 392 is currently making 430HP, swapping out and putting on the AFR 205's is going to be best done with a cam swap as well.
I am just over 500HP on a 408 with 205cc heads. 544TQ. Basically switch those numbers, give or take 10HP and TQ, for 205cc heads.
On a 392 with the cam profile required to make 430HP, your best bet would be 185's. You would see a more proportional increase in both HP and TQ because it is just a better head than what you have now, but similar port sizes, most likely.
Hey...you mentioned a "knowledgeable source" . . . we're ALL "knowledgeable sources"
If you ask 1,000 engine builders 205cc or 185cc AFR's for a 392 with your numbers, you will get about half of each answer, I bet.
To each builder, a different opinion.
Dart makes great stuff. I like my AFR's... If I were to "improve" my motor, I'd put a solid cam in w/ a little more lift & duration, go to 205cc heads, and bump compression up 1/2 point. That would probably take me from 508 to 575-600 range (HP)...
FWIW
J.P.
Ohio Cobra Club
Token Gashole
