Old 01-20-2005, 12:35 AM
boxhead's Avatar
boxhead boxhead is offline
With your jag front end all you need to keep and use are the parts that come off when you remove the 2 9/16 bolts that hold the upper inner control arm pivot and remove the long lower control arm inner pivot, remove the tie rod ends from the spindles and cut the brake hose.
Keep the upper and lower arms, keep the spindles, rotor and caliper, keep the lower control arm mounting bolts, keep the upper control arm inner pivots.
When I get home I will post a pic showing all the parts you need to keep.
Cruising in 5th
