Old 01-22-2005, 09:05 AM
427 S/O's Avatar
427 S/O 427 S/O is offline
See if you can find a set of C6AE U heads, small combustion chamber, good heat, good burn and cheap. They are also high compression but, you can have a torque cam ground to bleed off a little, C7 rods, well balanced cast crank and the rest is your choice. If aluminum heads were so much better, I would have had them long ago......
Perry
