Old 01-25-2005, 03:26 PM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
I was reading an old article on sports car suspension tuning. The real term "British" for the symptom is JUDDER.
The article implied that judder is typically caused in order of probablility (assuming the tire and wheel are balanced):
1) out of round tires or separated belts/plies
2) out of round wheel or bent wheel
3) steering rack slop or mis-alignment
4) loose lug nut(s) or pins
5) worn tie rods or bushings
6) hung brake caliper or drastically warped rotor
7) bad bearings or spindle
8) non-isolated steering column (no rag joint or bushing)
It appears that most of us have 8.
However, 8 does not cause Judder it just allows the vibration to be felt at the wheel.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
