Old 01-26-2005, 04:46 AM
MetaJacko's Avatar
MetaJacko MetaJacko is offline
Cobra Make, Engine: Metaline 1969 Ford 390 bored to 402ci
Hi,
The simple answer I think is ether 'Ford Engine' or 'Ford Edsel' (I may have spelt Edsel wrong)
What I think you mean is 'what is the relevance of FE' since obviously there are a lot of 'Ford Engines' but not all are FEs
Basically it is a block design and relates to a series of engines with different bore and stroke 352, 390, 406, 410, 427, 428 CI. (There may be others I've missed) and is considered a big block.
I beleve it was replaced in late 60s by 429, 460 (again both are the same block but different bore/stroke)
Someone else may give some more detailed info but I hope this helps.
Paul
