Old 01-26-2005, 01:21 PM
steelcomp steelcomp is offline
Default 460 motor for sale
1) 460 Ford + .030 D1 block fully deburred and casting flash removed, L2404 forged pistons and moly rings, polished truck/CJ rods w/ARP bolts, stock 460 crank 10-10 w/ Clevite brgs, precision balanced, (1) C8VE, and (1) D0VE head, stock valves, screw in studs, Isky 5/16 pushrods and guide plates, Isky chromoly retainers, Boss 351 adjustable rockers, poly locks. Melling hydraulic torque cam, 490"/515" and 204/214 @ .050". Cloyes true roller, Truck rear sump pan w/ stock oil pump. M/T finned alum. valve covers. Will consider cam/spring change. Will add roller rockers for extra...zero time since freshened up, less than 7000 mi....$3500.00/ offer.
(1) Cast iron 429 CJ intake manifold...used...$150.00
(1) Cast iron Ford 429/460 bell housing, flywheel, HD oem style clutch and disc...used, low mileage...$200.00
scotfox@earthlink.net
