Old 01-27-2005, 08:38 PM
Edley Rondinone Edley Rondinone is offline
Cobra Make, Engine: NAF replica, 351W, about 420 HP
I am just guessing, but is the frame straight?
Is the frame "square"?
Is the wheelbase the same on both sides of the car?
Are the shocks worn to a point that there is "judder" emanating from them?
Are the shocks adjusted the same?
Are the coil springs adjusted the same?
Is the steering column mounted securely to the frame and everywhere else?
Are the universal joints in the steering column in good shape?
Is the steering wheel mounted securely to the column?
Edley, The Cobra Rogue!
"If you think that you can cut it, if you think you got the time, you'll only get just one chance, better get it right first time. 'Cause in this game you're playing, if you lose you got to pay, and if you make just one wrong move, you'll get BLOWN AWAY. Expect no mercy.
